BIZHUB 920
  • konisolver
    System Engineer
    • Oct 2007
    • 137
    BIZHUB 920
    Have a 920 when copying or printing 11x17 sort mode it throws some of the sheets to the floor. Kind of flying towards the rear of the finisher as it comes out. Also when copying/printing 8.5x11 non-staple face up every other copy will be off from the rest of the stack. I have replace the finisher exit and conveyance motor, the shifting assy, FNS CB and have re-adjusted the exit drive belt tension. Any suggestions?
  • tech51
    • 846
    .Sounds like you have offset sorting turned on. Go to your finishing options and turn it off
    • konisolver
      System Engineer
      • Oct 2007
      • 137
      Thanks. I forgot to mentioned the unit is program for sort on all jobs.
      • RockETop
        Curmudgeon at large
        • Apr 2007
        • 171
        Did the FNS exit replacement include the sponge rollers?
        • Coptech
          worker drone
          • 460
          If I recall, the exit assembly gets you the top half only. As mentioned, replace the sponge rollers and follow the solenoid adjustments in the book. They are critical, touchy, and make a huge difference in the way that the paper exits the finisher. Also, the small toothed belt and drive pulley at the exit can slip and it has no tension adjustment. Just replace if it is slipping.
          • konisolver
            System Engineer
            • Oct 2007
            • 137
            The rollers were replaced but never played with the solenoid. Thanks I will give it a shot.
            • Coptech
              worker drone
              • 460
              The solenoid actually has 2 adjustments and they are in the copier service manual adjustments section. Funny that they are not in the finisher service manual.
