Bizhub C552 with C3722 code
  • DCtrouble
    • 19
    I have a new C552 with C3722 code. I can reset the code, but it comes back. I monitored the fuser temps in Service Mode, the temps are all over the place on Edge,Center and NC sensors. Don't see break down for fuser unit in parts guide. I would hate to have to replace brand new fuser.Any other suggestions? DC Trouble
  • DCPS
    • Mar 2008
    • 116
    Does the machine work for a while before the code come back again?
    • DCtrouble
      • 19
      Yes, for a while meaning a day. I thought about it some more. It could also be a bad connection between fuser and PRCB. Still open to other ideas.
      • Albonline
        • Sep 2008
        • 1151
        there are three ir sensors on the copier frame. try tradeing their positions around. i think the one on the back side of frame is only used when the other 2 fail. redundant thermal protection.(remove fuser and you will see plastic bracket they are mounted in)
        • DCPS
          • Mar 2008
          • 116
          Yes it should be one or more of these sensors.
          • kmcopier
            PSP
            • Oct 2008
            • 183
            there is special firmware for this 59 spec and also solved in 88
            <Workaround>
            Change the setting time of Low Power Mode setting as longer than the time of Seep Mode settings.
            Administrator Settings -> System Settings -> Power Save Settings
            -Default settings
            Low Power Mode Settings: 15 min. Sleep Mode Settings: 30 min.
            -Workaround (For example)
            Low Power Mode Settings: 35 min. Sleep Mode Settings: 30 min.
            -Note
            Sleep ON/OFF Choice under Service Mode has to be set [Prohibit] as default settings.
            System1 -> Sleep ON/OFF Choice: Prohibit
            <Countermeasure>
            -Temporary measure
