Print problem with minolta c250
  • robizhub
    • Sep 2008
    • 36
    HELLO
    I Have an intersting print problem:
    When a A3plus sheet are almost empty - we have a small image and a few word (black color) - after printing the entire sheet are covered with a gray color like I put 5% or max 7% gray.
    But I like the sheet to be white not gray because the gray are not in PDF.
    Thanks!
  • Albonline
    • Sep 2008
    • 1151
    you may hve to adjust the 2nd xfer voltage for the papar weight that you are running.
    • robizhub
      • Sep 2008
      • 36
      I added an image
      so somebody can help me
      The gray are present also if the thick of the paper are low (normal paper)
      The image I've added is a book cover have to be paper color not that gray.
      • Albonline
        • Sep 2008
        • 1151
        question: does the copier do this when copying also?
        • robizhub
          • Sep 2008
          • 36
          Thank you for aswer,
          Yes are the same problem!
          • Albonline
            • Sep 2008
            • 1151
            try this
            • robizhub
              • Sep 2008
              • 36
              To Albonline:
              Thanks for help!
              Gray has disapeared!
              Image looks good!
              Problem has been solved!
