Hello, anyone having problems with the sep claw on the transfer belt flipping under and wrecking the belt and if so has anyone been taking them off? Had 2 last week do this and ruined both belts. I noticed the 552/652 don't have the claw so wandering if I can just remove before installing. Thanks
Bizhub C203/253/353
Tags: 253, 353, 552, 652, back, belt, belts, bizhub, bizhub c203, c20, c203, flipping, fuser, incorrectly, installing, off, stalling, transfer, transfer belt, transfer belt cleaner
never heard of the claw flipping on itself but i do face belt ripping due to the paper used by customer that has some kind of glue that cause the claw touching the belt and ripping it.Comment
I have had one unit do this..but I think it was caused by user feeding heavy stock from bypass and it jammed at fuser, folded onto belt/claw. I have not tried removing them but suggest you make sure that the mounting plate is not bent up at all.Please do not PM me without asking first.Comment
I`ve had a few like this, normally happens after a lot of J30-01 jams, paper tends to hit the transfer belt claw. I would check the jam list to see if there`s an underlying jamming issue. I wouldn`t remove the claw, I saw this done on a C650 once and the result was loads of paper in the transfer belt cleaner.Comment
