C6500 with Fiery IC-408 embedded Print Controller
+ More Options
Posts
  • drodas78
    • Jun 2008
    • 91
    Hi.
    I have a C6500 with IC-408 Fiery embedded print controller. About 6 months ago the "controller" button suddenly disappear from the control panel in the machine. I have turned it off and on and the controller appear again but it became more frequently in the latest days and today the "controller" button dissapear from the control panel and I do the same, turned off and on the fiery but the machine doesn't recognize the fiery.
    Can you give some advice to fix this?
    Thank you!
  • RRodgers
    • Jun 2009
    • 1947
    The Hard drive of the Fiery might be going out or it's full. Do you know the IP of the Fiery? Can you ping it? Have you tried connecting to it with Command Workstation?
    • drodas78
      • Jun 2008
      • 91
      Hi. I tried to connect with Command WorkStation but It says server connection error. The status of the fiery start with FF then some numbers and then FF again and nothing more.
      I Ping it and everything seems ok Packages sent = 4 receive = 4 Lost = 0. I enter in my web browser address: http://192.168.1.124/ and I can see the panel to edit the preferences of the fiery but it says: Please enable SNMP and the title of the page is "Error". I tried to enter into Admin Mode to see if I can do something. I enter the password: "Fiery.1" but it says it is incorrect.
      How can I delete the files in the HDD of the fiery? Can I connect it as slave in a PC to erase the files? If the HDD has gone can I buy some HDD and make the fiery works?
      Regards.
      • RRodgers
        • Jun 2009
        • 1947
        I can't remember if server clear deletes the jobs or all the settings for the fiery.
        • drodas78
          • Jun 2008
          • 91
          What do you mean? Can I run a command to instruct the fiery to clear all the jobs?
          • TheOwl
            • Nov 2008
            • 1732
            Server Clear (from the setup menu or Command Workstation) clears all job data from the Fiery without touching any of the Fiery settings.
            By the sounds of it, you might have an HDD that has slowly failed. Chances are that you will need to replace the HDD in the Fiery and then reload the system software. If you have another IC-408 available to you, then I would suggest cloning the HDD out of the good one, then replacing the HDD in the bad controller and using the image from the good controller on the new HDD.
            This is much quicker than manually laoding the system software onto the Fiery.
            I would recommend using something such as Acronis or Ghost to create you image from the working HDD. Acronis is easier to use than Ghost, so I would go for that if you don't have any experience cloning HDD's.
            Hope this helps.
            • drodas78
              • Jun 2008
              • 91
              Thank you for your answer! Unfortunatly I don't have another Fiery IC408 in my whole country. I'm from Guatemala. I'm wondering if you can help me further more.
              I can use Acronis but I need the image files. Can you upload it to a torrent or can you send me copy of the image files in DVD trough DHL? I would pay for your job and for the transportation cost. I really need your help. And I will appreciate it very much.
              Or I would appreciate if you can give me directions to upload the system software onto the fiery manually in a new HDD.
              Warmest regards.
              • Si@danwood
                • Mar 2008
                • 154
                Try just reloading the system software,this is on a disk that will have been supplied with Fiery.It takes about an hour and 3/4 and will be the fastest way of getting the machine working,whilst you decide wether to go down the route of sourcing an alternate HDD!
                • TheOwl
                  • Nov 2008
                  • 1732
                  Unfortunately, my image for the controller is 29GB, so uploading it is out of the question and I don't have the system software disks as I use my image.
                  I am sure that there would be someone with in these forums that would supply you with a copy of the system software DVD and the instructions for the restore can be found in the service manual for the IC-408.
                  • drodas78
                    • Jun 2008
                    • 91
                    Can you give me the instructions to reload the system software?
                    Thank you!
                    • Si@danwood
                      • Mar 2008
                      • 154
                      Sent you a pm as soon as i hear back the info is yours
                      • stathistec
                        • Nov 2008
                        • 17
                        hello
                        this is the service manual for ic 408
                        you will found the way to re- install the software
                        • drodas78
                          • Jun 2008
                          • 91
                          It worked!
                          Hi thank you to all who helped me out!
                          The machine is working again. But I tried to calibrate the fiery wit color cal and the scanner calibration goes ok but the color calibration give me the following error:
                          Calibration Error
                          0x00000024
                          Measurement page is not detected
                          I tried also to make an auto gray from the color editor but I got Measurement page is not detected (36) error again.
                          Any ideas to calibrate the machine? Do you think that is good idea to replace the HDD of the fiery?
                          • RRodgers
                            • Jun 2009
                            • 1947
                            Calibration Error
                            0x00000024
                            Make sure the optics are CLEAN!! I've had this once and turned out to be dirty optics.
                            • stathistec
                              • Nov 2008
                              • 17
                              you must calibrate the machine with es-1000
