We have a problem with thin lines across the page that are on the transfer belt. We've replaced the transfer belt unit but this has not fixed it. It looked like a cleaning fault also the belt was nicked too. These lines are black,magenta and yellow about 50mm apart acoss the page. Any thoughts
Konica Minolta c353 Thin Lines
We have a problem with thin lines across the page that are on the transfer belt. We've replaced the transfer belt unit but this has not fixed it. It looked like a cleaning fault also the belt was nicked too. These lines are black,magenta and yellow about 50mm apart acoss the page. Any thoughts -
Yes printing and copying. U can see lines formed on belt which that rub off (More like latent image) lead me to replacing unit ,especially as belt was nicked too. Can't be pcus as lines are all colours- guess must be drive? to transfer unit. All my experience is with Ricoh, so i'm going in bit cold and learning as i go, got the manual so thats something.....Comment
Does it look like sheet music? Had a c203 do that and it turned out to be the mfp board!
Regards!
A.Comment
