Konica Minolta c353 Thin Lines
  • Del Clack
    • Jun 2008
    • 8
    We have a problem with thin lines across the page that are on the transfer belt. We've replaced the transfer belt unit but this has not fixed it. It looked like a cleaning fault also the belt was nicked too. These lines are black,magenta and yellow about 50mm apart acoss the page. Any thoughts
  • bizhub1
    • Sep 2008
    • 230
    How many prints on this machine?
    • Del Clack
      • Jun 2008
      • 8
      Cant remenber, maybe 90k b&w? but belt nearly done life..
      • bizhub1
        • Sep 2008
        • 230
        Does this happen on both copies and prints?
        • Del Clack
          • Jun 2008
          • 8
          Yes printing and copying. U can see lines formed on belt which that rub off (More like latent image) lead me to replacing unit ,especially as belt was nicked too. Can't be pcus as lines are all colours- guess must be drive? to transfer unit. All my experience is with Ricoh, so i'm going in bit cold and learning as i go, got the manual so thats something.....
          • tech51
            • 846
            Could you scan in a sample of this fault? It could well be the mfp board as they can cause this fault. But without seeing an example its hard to tell..
            • copytechman
              • Nov 2008
              • 947
              Does it look like sheet music? Had a c203 do that and it turned out to be the mfp board!
              Regards!
              A.
              • bizhub1
                • Sep 2008
                • 230
                I had one do this but it only did it during copying and it was the mfp board.
                • Del Clack
                  • Jun 2008
                  • 8
                  No this a normal cq fault as such. Has been suggested in our office that IU chips may have been replaced so units may be causing fault- obviously they are showing only 20% or so used
