Yellow background on copies on CF3102
  • Astermarc
    • Mar 2009
    • 46
    Again I have problems ..... This time a yellow stain on the pages copied. And printing and copying is in the same position: top right corner. I removed all units, at a time and we clean, we clean the inside well, I checked the transfer belt, fuser;we cleaning optics. None of this did not solve my problem. Does anyone know the where and how can remedy the situation? Here is a copy
  • Kmdurrin
    Copy/Print/Network Tech
    • Dec 2008
    • 132
    Have you replaced the yellow IU yet?
    Parts: Its what your copier craves!
    • Astermarc
      • Mar 2009
      • 46
      Still not the case. But I began to have this problem: suddenly
      • Astermarc
        • Mar 2009
        • 46
        K...I changed yellow IU and yet still have the same problem. Any suggestions???
        • Albonline
          • Sep 2008
          • 1151
          did you output halftone patterns for each color? try sticking a magnetic screwdriver into the toner collector box, does metal come out? on the sample copy you put up is the background supposed to be white or light blue?
          • Astermarc
            • Mar 2009
            • 46
            What bothers me is the orange-yellow stain upper right corner. Do not know what to do because it is clean everywhere.
            • RRodgers
              • Jun 2009
              • 1947
              Do prints do this as well or only copies?
              • Astermarc
                • Mar 2009
                • 46
                Both! Whether print or copy is the same problem and same place. I tried what Alboline suggested - "try sticking a magnetic screwdriver into the toner collector box, does metal come out?" - but I found that everything is in order: no metal on screwdriver
                • Albonline
                  • Sep 2008
                  • 1151
                  did you output halftone patterns for each color? did you ?
                  • RRodgers
                    • Jun 2009
                    • 1947
                    Double check the interface cable for a bent pin.
                    • Astermarc
                      • Mar 2009
                      • 46
                      Looks like this:
                      • Astermarc
                        • Mar 2009
                        • 46
                        We changed the chip of the IU yellow. And yet no remedial action.
                        • mrwho
                          Major Asshole!
                          • 4299
                          The chip doesn't help, the only thing it does is resetting the counter. As for the examples you posted, it looks like some problem with the transfer belt's cleaning unit. Do you have a spare used transfer belt that you can try on that machine?
                          Mascan42
                          Ibid
                          • Astermarc
                            • Mar 2009
                            • 46
                            I don't have another. Can I remove the transfer belt's cleaning unit and clean the blade? It could help this action?
                            • RRodgers
                              • Jun 2009
                              • 1947
                              You can, not sure if it would help but you can. Slides out the left side and just 2 screws that hold it in. (one on each side, they are black)
