c452,552, 652 belt and fuser reset
  • masterteknicion
    • 48
    Does anyone know if these models have the fuse you can replace on the fuser and the belt to reset the electronic counters.
    If so where would I find them.
    Thanks for your help.
  • MR CLEAN OC
    Fuse no longer needed, reset now available in the tech rep mode for transfer belt and fuser.
    • tech51
      • 846
      Just make sure you have the front door open when you re-set the counters. Doesnt re-set if door is shut.
      • masterteknicion
        • 48
        Thanks for the replies, got it taken care of.
        • Printer People
          • Oct 2010
          • 43
          Re: c452,552, 652 belt and fuser reset
          Just had the unit apart as i was resetting a C451 at the same time. Put it back in and now trolling through the service mode.....for the life of me i cannot see how I reset the count, I can see the fuser count but can not highlight it to reset it. Am i missing something or in the wrong place.
          • Synthohol
            Certified Konica Expert
            • 5892
            see any box on top in life counter that says new release? if not its too old. you will need a .063A (1/16A fuse)
