Bizhub 500 Quality issue with picture
  • Matt25112
    • Mar 2008
    • 38
    I am heading out to the customers machine right now...have in shop machine to bring drum, developer, transfer sep just to trouble shoot. Thinking fixing motor clock timing or something I really don't quite know yet. This is an internal test print #1. It is also doing this when copying.
    [IMG]file:///C:/DOCUME%7E1/matt/LOCALS%7E1/Temp/moz-screenshot.png[/IMG][IMG]file:///C:/DOCUME%7E1/matt/LOCALS%7E1/Temp/moz-screenshot-1.png[/IMG]
  • Matt25112
    • Mar 2008
    • 38
    No luck...I have an in shop machine to swap parts with.....any suggestions. I stopped the machine mid print and I can tell you the drum looks good but the image is being put on before the fuser so I am thinking the back end of the print is whipping away from the drum...
    • RRodgers
      • Jun 2009
      • 1947
      Try a thicker piece of paper and see if it does the same thing.
      • mo0651
        • 1054
        How many copies? Need a pm? A little more info might help.
        • Matt25112
          • Mar 2008
          • 38
          Developer was replaced 93k ago, image on drum looks fine though, I think it is a contact issue with transfer sep. Depending on how easy it is I may take the side door/transfer door or certain parts of it off our machine and pop it on there just to get this thing down to an area. Customer is not in desperate situation as they only see this problem on higher coverage jobs.
          • Matt25112
            • Mar 2008
            • 38
            Will do with the thicker paper...
            • BIG PAPA
              Da Boss
              • 234
              Had similar issues in the past, cleaning T&S usually took care of it for me. Machines would dump into transfer and effect bias. cleaning wires would resolve. Have you tried a different T&S Unit?
              sigpic
              • mo0651
                • 1054
                Cleaning both trans/sep wires will work in some cases. Check the main charge wire also. Scotch brite all the copper grounding contacts on that door and frame while you are in there!
                • copytechman
                  • Nov 2008
                  • 969
                  Seconding cleaning xfer unit wires etc, seen that symptom too!.
                  Regards!
                  A.
