BIZHUB 601
  • thuo
    • 155
    BIZHUB 601
    Hi
    i have a bizhub 601 which has a constant paper jam at the fixing unit just before the paper exit.when making single sided the paper takes the duplex paper path i have tested the machine with a working machine but behaves the same.
    NB. the paper passes thru the fuser unit but but takes the duplex paper path.
    please assist.
    thanks
  • Deas
    • May 2008
    • 10
    Can you check to see if there is any guide that are in the wrong position?
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      This machine send the paper to the first part of the duplex unit then reverses it and sends it out the exit unit. This is so the paper exits face down. I would suspect a dirty sensor. What error/jam code does it give?
      • bizhub1
        • Sep 2008
        • 230
        Also check the foam roller right out of the fuser, have had to replace these for that problem
        • thuo
          • 155
          BIZHUB 601
          I will replace the foam roller.Could you please advise me on most probable faulty sensor
          • racosta
            • 53
            Might want to check the white one way gear also. I have seen that cause jamming issues as well.
            • Spidula
              Konica Minolta Technician
              • 83
              Check the bushings on the Sponge decurl roller and the shaft above it also. These can wear and cause jamming too.
              What is the copy count on the Fuser?
              • montana
                • Aug 2008
                • 393
                hi....clean the foam roller &check the paper exit sensor and flag
