BizHub 250 misfeed detected
  • abbas saeed
    • Mar 2010
    • 31
    How are you
    I have a problem I went to one customer and told me that there is paper stuck in between the side cover
    And then removed as usual at a time
    But this time, you know that the machine remained a paper stuck or side cover is not closed
    With the paper removed and the side cover is closed but the issue still exists
    Illustration in the annexes
  • minimerlin
    • 851
    You either still have a scrap of paper in the areas indicated..or a broken/stuck actuator or sensor!
    Please do not PM me without asking first.
    • rocky246
      • Feb 2007
      • 91
      An actuator on the switchback unit has a spring on it that likes to pop off. It indicates a jam when this happens. Above the fuser in the middle of the switchback unit.
      • abbas saeed
        • Mar 2010
        • 31
        Thank you
        I went early to the customer the day after to make sure the integrity of the sensor and when my question to the customer
        Is the paper fully removed?
        He told me yes
        It turns out that there is a very small piece of paper
        Thank you
        • minimerlin
          • 851
          Originally posted by abbas saeed
          Thank you
          He told me yes
          Thank you
          Glad you got it fixed..as it happens I had exactly the same fault at one of my customers today and yes they had left a scrap of paper in the vertical guide!
          • abbas saeed
            • Mar 2010
            • 31
            True
            Most errors easy but it remains difficult to detect
