C1109 on C652 w/ FS-526
  • emujo
    • Jun 2009
    • 3009
    I can run front or back corner staples with no problem, When I run 2 position staples, the stapler will go to the 1st spot, and nothing happens, FS just runs and runs, no code at this point. Stapler movement motor is frozen and can't be moved front to rear. If I look at the sensor check, the home position sensor is flagged. When I open the fron door, and close it the stapler will move to the 2nd stapling position and give a C-1109 code. I have replaced Fin main bd, stapler, and stapler movement motor, updated firmware. I'm thinking it may be a harness problem so I'm going back with back with both the home postion sensors and it's associated harness, and the stapler movement motor harness but I'm anly guessing at this point. Again, one position stapling works fine. Any thoughts? Emujo
  • emujo
    • Jun 2009
    • 3009
    Turned out to be the harness for the stapler/movement motor. EMujo
