Konica Minolta bizhub 252 is not loaded to the system at startup
  • LinART
    [Dead] Konica Minolta bizhub 252 is not loaded to the system at startup
    Konica Minolta bizhub 252 is not loaded to the system at startup. The screen shows a clock, then fades out the screen. I suspect that the problem with NVRAM. Now I want to write the firmware from the CF ... But I can not find it. Anyone can send an e-mail admin@sadmin.org firmware for 252p, for example, 4038-F000-G00-K0-300_CHECKSUM-6452 (Phase 3.05)? Or NVRAM recovery firmware bizhub C250/C252: 20070301_4038-F000-GCN-G4-000 (2000), Checksum: 16E6.EXE. Thank you.
  • RRodgers
    • Jun 2009
    • 1947
    Try a trouble reset first. Turn the machine on while holding down the Utility key.
    • LinART
      It did not help.
      • xsstaff
        hi there! please tell me if you managed the situation... i'm in the same position, and i can't find the nvram recovery for bizhub c252. if you need, i have the firmware you requested. thanks!
        • LinART
          I solved the problem with NVRAM recovery firmware bizhub C250/C252. I can share. Contact with PM
          • radew
            Konica C252 nvram problem
            Dear All,
            I also have the similar problem and been trying to program the copier without any success despite with the technician from the local copier company ..
            I will be grateful if someone could give me a pointer ?
            Cheers,
            Mao
            • Naveed Shahid
              • May 2008
              • 162
              Re: Konica Minolta bizhub 252 is not loaded to the system at startup
              can u send me solution i am also facing same problem
              thanks
              naveed
              toshiba_estudio@yahoo.com
              • ozkan
                • Feb 2018
                • 7
                Hi I have the same problem, but I couldn't find the firmware. Any suggestions?
