Bizhub 420/500
  • Jonzeboy
    • Jul 2025
    Bizhub 420/500
    Did anyone have problem with the trouble code cd282 on a Bizhub 420/500?
  • mauro
    cd 282
    Communication abnormality between the overall control board (OACB) and the scanner drive board (SDB). When the power switch (SW2) turn on, there is no SDB response.
    Check cable and connectors
    • Jonzeboy
      And then?
      • aleksander
        • 378
        do trouble reset.
        • DCPS
          • Mar 2008
          • 116
          Check ICP15 (2.3A) on Image Board (50GA-9020). I had a similar case.
          • Jonzeboy
            With the same error code? They only talk about overall control board and the scanner drive board in the service manual.
            • DCPS
              • Mar 2008
              • 116
              Yes with exactly the same code.
