monica minolta bizhub 750
  • navaneetan
    • Aug 2025
    [Error Code] monica minolta bizhub 750
    hi,
    i am getting error code c3803 in biz-hub 750, what is the solution ,and how to reset it?
    please help me.
  • Stirton.M
    All things Konica Minolta
    • Oct 2009
    • 1804
    C-3803 Thermistor /1 (TH1) detects a low
    temperature when a specified
    period of time elapses after the
    fusing heater lamp is turned ON
    for the fusing ON control.
    This most of the time is not a serious problem. Just a protection for the machine against fire. Though in this case, abnormal low temperature is hardly a fire hazard. The fuser, which melts toner to the page, had too much heat sucked out of it while running due to heavy stock or plastic coated paper. Or one of the heat lamps has stopped functioning.
    The code event locks the machine down, requiring a tech look at it for safety reasons. A bit switch is toggled to turn off the lock. Change Dip SW 3-1 to 0.
    Estimated abnormal parts.
    Printer control board (PRCB)
    Fusing heater lamp /1 (L2)
    Fusing heater lamp /2 (L3)
    Fusing heater lamp /3 (L4)
    Thermistor /1 (TH1)
    Thermistor /2 (TH2)
    result in a fire.
    "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
    ---Groucho Marx
    Please do not PM me for questions related to Konica Minolta hardware.
    I will not answer requests or questions there.
    Please ask in the KM forum for the benefit of others to see the question and give their input.
    • SmellsHot
      Head Tech
      • 512
      Make sure the connector under the fuser is plugged all the way in. Will blow this EXACT code everytime.....
      Everyone has the right to be stupid. Some people just abuse this privelage more than others
      • navaneetan
        every thing connected well, but i cannot enter in service mode i tried utility-metercound-stop-0-0-stop-0-1,but it is not entering in service mode.....
        • Spidula
          Konica Minolta Technician
          • 83
          Try a trouble reset
          Power machine off and power back on whilst holding utility/counter button. Keep your finger on until "Trouble reset" is displayed on the LCD screen. Touch trouble reset on the screen (ok will appear below) and power off and back on again. This should clear the code.
          • copier tech
            • 8174
            Re: monica minolta bizhub 750
            I have the same issue, but on a 751.
            In order to reset the error do I use trouble reset or the SW setting as mention above?
            DipSW3-1 to 0.
            • laitang
              • Nov 2012
              • 627
              DipSW3-1 to 0.
              From SM:
              • Aquitas
                Currently struggling with this. I'm gonna try it now.
                • allan
                  RTFM!!
                  • 5462
                  Hehe.
                  Goeie werk.
                  Bel jy nie meer jou vriend nie?
                  Whatever
