konica minolta pro c500 security lines on color copy (black monocrom copy is ok
  • costel fasola
    • Jun 2010
    • 69
    We park a Konica Minolta bizhub PRO C500 equipment that at some point all had to reset (to reset the memory and Board) as it burned laser engine gave me no engine code. I changed the engine angled drive after installing laser black but my security streaks appeared and can not get rid of them. One copy is on magenta , one copy is on cyan.- descriptions security lines. in service mode the machine printing ok. in the working mode prin, copies in black (monocrom) copies is ok. color copies or color printig is on lines (security lines). please help
  • costel fasola
    • Jun 2010
    • 69
    http://www.copytechnet.com/forums/ko...0-problem.htmlTransfer de fisiere foarte mari (pana la 1GB). Transfer.ro
    attach in 10 min to 1 GB
    Report this text to a moderator 89.44.239.243 (?)
    costel beans
    Global Moderator
    Hero Member
    • costel fasola
      • Jun 2010
      • 69
      Transfer de fisiere foarte mari (pana la 1GB). Transfer.roAdobe - Adobe Reader download - All versions.
      Notes: This mode is for diagnostic testing purposes only. Will this allow both black and white / color copies and prints, the leg color copies / prints Will have
      Security lines on Them. "-what I found ...
      Bulletin Number 4982 of Konica Minolta has anyone?
      Bulletin Number 4982"
      please help
      • costel fasola
        • Jun 2010
        • 69
        Transfer.ro - transfer profesional de fisiere foarte mari (chiar si de 1GB #s4)Adobe - Adobe Reader download - All versions.
        please help
        • costel fasola
          • Jun 2010
          • 69
          i did resset on the memory board right on the manulal of the konica 7085 "all solutions manual" but i thist is not dit right. sow 2 questions:
          1: how resset memory board on konica minolta pro c500?
          2. how get rid of security lines after resset memory board of the konica minolta pro c500?
          please help
          thank you in advance
          • costel fasola
            • Jun 2010
            • 69
            problem remain....sow please annyone help-me.
            please help
            • costel fasola
              • Jun 2010
              • 69
              solution for this problem:
              replace controlller all 4 boards with prcb board form ATENTIONS ! same machines and rewrite firmware an is working.
              problem is nv-ram .nv ram most rewrite in the konica-minolta factory .
              topic is close
              • shahidmalik
                security lines appers in c 500 bizhub
                one copy on cyan and one copy on maganta i reset the copier factory defalt setting then problem plz help
                • Albonline
                  • Sep 2008
                  • 1150
                  run through the setup procedure,step by step.
                  • shahidmalik
                    plz explian it
                    which set up need to run step by step thanks .shahidmalik@hot mail.com
                    • ineo+6501
                      • Mar 2010
                      • 262
                      Download the installation instructions from CSES and follow it as if the machine was brand new and you have just taken it out of the box. Simply miss out the shipping bracket sections and skip to the engine setup.
                      • costel fasola
                        • Jun 2010
                        • 69
                        i just did that....and is not working...is need reset nvram in kkonica minolta factory....
                        for resolve the problem i replace all 4 boards....from the same machines., initiate exacly new one and is working verry well
                        • Stirton.M
                          All things Konica Minolta
                          • Oct 2009
                          • 1804
                          Yes, if there is a mismatch between the boards from factory setup, a lot of hoops need to be jumped to correct the problem. Just tossing in a new board and walking away is a sure way to encounter issues like this.
                          "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
                          ---Groucho Marx
                          Please do not PM me for questions related to Konica Minolta hardware.
                          I will not answer requests or questions there.
                          Please ask in the KM forum for the benefit of others to see the question and give their input.
