konica 7155 "close front door" message
  • Kevin Ransom
    • Sep 2024
    [Electrical] konica 7155 "close front door" message
    adu driver pwb, print and system pwb, front door switches and memory parameter board all have been replaced...also dc power supply. door switches activate transport release solenoid when activated. 24v at door switches. pulled transport unit and activated door switches-get 32-09 fuser jam code. any other suggestions?
  • dallas
    • Jun 2008
    • 115
    In the past, i have had on a Bizhub 600 the message "Open Door".
    In this case, PS38 was failed. Check PS39 also.
    • Albonline
      • Sep 2008
      • 1088
      yep, like he said
      • Kevin Ransom
        update to "close door" message
        Tried ps38/39, swapped entire adu/transport unit, laser. Still no change.
        • RockETop
          Curmudgeon at large
          • Apr 2007
          • 171
          That is the End Of Life message for this machine!
          • DCPS
            • Mar 2008
            • 116
            With the ADU unit did you also swapped the ADUDB? I had the same error and it was the IC5 on the ADUDB (STK672-120 if i am right) wich had a short.
