C550 error code C-2204
  • connecticcut
    • Feb 2010
    • 53
    the motor turn (waste toner) but i have always this code error
  • Spidula
    Konica Minolta Technician
    • 83
    Is copy qual bad?
    If it is it could be cleaner motor (M38) and the gear below which is shot. I had this a while back and it chucked up 2204 codes.
    Take transfer belt out. Take left side cover and metal cover directly beneath that off, and you can see the motor and gear at the back of the m/c. It drives the cleaning section in the trans belt.
    Bit of a pig to change!
    Hope this helps
    Spid
    • minimerlin
      • 851
      Is the waste bottle just fitted? I have had a few failures (c-2204) caused by the flag operated by the drive gearing failing..worth looking at before the gears are pulled.
      Please do not PM me without asking first.
      • connecticcut
        • Feb 2010
        • 53
        thanks.
        I have to find,this is waste bottle.When i move the gear on waste bottle,the metallic lever don't come in front sensor (s23).It were a new Katun bottle..
        • minimerlin
          • 851
          Glad to save you the hassle of a motor swap!!
