C550 error code C-2204
thanks.
I have to find,this is waste bottle.When i move the gear on waste bottle,the metallic lever don't come in front sensor (s23).It were a new Katun bottle..Leave a comment:
Is copy qual bad?
If it is it could be cleaner motor (M38) and the gear below which is shot. I had this a while back and it chucked up 2204 codes.
Take transfer belt out. Take left side cover and metal cover directly beneath that off, and you can see the motor and gear at the back of the m/c. It drives the cleaning section in the trans belt.
Bit of a pig to change!
Hope this helps
SpidLeave a comment:
the motor turn (waste toner) but i have always this code error
