Does anyone knows how to reset error code c3751? I tried to replaced the fuser unit thinking that would reset it but still come up.
KONICA MINOLTA BIZHUB c351
albasoul06
C3751: Abnormal high temp. (heater)
restart machine, holding utility key and do trobel reset, if it fix this problem, everything is ok, if not, call for service
http://www.copytechnet.com/forums/ko...ode-c3751.html -
Thanks albasoul06, the thing is i'm the service lol.
i have an itravia book for the c350 and says to reset on the board but couldn't find a board.
i will try holding down the utility key.
thanksComment
I believe it's under system 1 in tech mode. Run the "system error clear" NOT the init machine!Color is not 4 times harder... it's 65,000 times harder.They call it "TECH MODE" for a reason. I have manual's and firmware for ya, course... you are going to have to earn it.
On the C351, that machine is electrically equivalent to the C450, the only difference is the speed. The reset sequence for the C351 is the same as the C450."Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
---Groucho Marx
