Ghosting on Black Copies C451
  • Eugene74
    • 70
    [CQ] Ghosting on Black Copies C451
    Hi there
    Try to scan in a sample but even on 600dpi it doesn't show on the scanned file, so I'll try to explain to the best of my ability. The problem seems to fluctuate, sometimes darker ghosting than other times. We have had this problem in various degrees for the last 700,000 copies. Everytime the problem comes up we replace parts (different parts) and it seems to go away for a while, just to return later. The majority of the copies done are black, this problem only occurs with black copying or printing. If there was any colour on the page together with bold black printing the problem does not occur.
    The following has been done to try and rectify the problem:
    Replaced the black dev units
    Replaced the MFP board
    Tried different firmware versions
    Did the black I.U. modification
    Replaced transfer belt and rollers.
    Did transfer settings as per bulletins
    Varied fuser transport speed.
    Various other settings as per bulletins.
    I'm now completely out of ideas.
    Many Thanks.
  • Eugene74
    • 70
    Saw that somebody had similar type of problem on C550, gona try it and will let everybody know.
    http://www.copytechnet.com/forums/ko...1392-c550.html
    • fixthecopier
      ALIEN OVERLORD
      • 4714
      Did you do the basics? Did you clean the lens on the printhead with the wand. Whenever I have a c450 ghosting black, I just use the wand and scrub the lens and it goes away.
      • Eugene74
        • 70
        Thanx for the input fixthecopier. I've just came from the customer, cleaned everything including the printhead lenses. According to my earlier post, that somebody had problem on C550 I followed the suggestions, stuck piece of tape at guide plate, but didn't seem to have sorted out the problem. Then as a last resort we removed the "Blue Resistor" behind transfer roller assembly, and our ghosting dissapeared. I'm not to sure what the resistor is there for, and if I fixed a fault with another fault. Try to look through service manual if there is an explaination to the resistor, but no luck. Going to order the guide plate modification and put it in and then if need be, put resistor back in place. If anyone know what the resistor is there for please let me know, seems like it got something to do with grounding or maybe static discharge..... Not to sure.
        • Konica_jr
          • Aug 2010
          • 25
          maybe you have to change the laser unit assy or try a " data clear "
          " French do it better " ^^
          • minimerlin
            • 851
            The mod mylar is the fix, normal electrical tape does the job as well but you need to shape it like the mod kit! I have used this on many occasions..it works!
            Please do not PM me without asking first.
            • jackson
              • Mar 2010
              • 19
              part no A00H703400
              • Eugene74
                • 70
                Thanks everyone, and this is the part no. I also got, but seems to me that our HO never brought it into the country or maybe under another number. But definitly going to make a plan to get it.
                • Printer People
                  • Oct 2010
                  • 43
                  Re: Ghosting on Black Copies C451
                  Originally posted by jackson
                  part no A00H703400
                  Does anyone have the info on this mod - were it fits etc?
                  • sidney
                    • Apr 2016
                    • 4
                    Sends a print image
                    Enviado de meu SM-G531H usando Tapatalk
