color shifting c6500
  • jhbtech
    • Oct 2010
    • 14
    [CQ] color shifting c6500
    hi all
    I am busy with a konicaminolta c6500 and have a color shift issue on SRA3 300 gsm paper.yellow shifts quite previlentat the trail side of paper.magenta also shifts before the yellow on the same page.I have changed transfer unit,transfer pulse disc,changed transfer belt speeds up and down with still no joy.
    On 80 gsm the image is fine.
  • Stirton.M
    All things Konica Minolta
    • Oct 2009
    • 1804
    Appears that your registration sensors may be at fault.
    Do a colour registration adjust and see if that corrects the problem. You may also need to open up the machine to get at the sensors themselves and clean them of dust. In severe cases, replace the registration assembly itself...
    "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
    ---Groucho Marx
    Please do not PM me for questions related to Konica Minolta hardware.
    I will not answer requests or questions there.
    Please ask in the KM forum for the benefit of others to see the question and give their input.
    • jhbtech
      • Oct 2010
      • 14
      i have replaced that unit as well.currently swopping drum drive unit around.to best describe problem,client is printing business cards with white text in them(24 up)some cards will have yellow in the text and others will have magenta in the text
      • HORSE
        • Mar 2008
        • 185
        White Text in a solid color on heavy stock will do this especially at 300-360mm from lead edge of SRA3, it tends to knock the magenta out by 1/2 pixel and on small text tends to fill in with a red tinge. Like you say do the same job on plain paper and its perfect. Caused by fuser shock transfered up the Tx belt.
        Its a limitation of the machine.
        Try using a line screen and see if it improves any.
        Laughing......
        • Stirton.M
          • Oct 2009
          • 1804
          Having a thought....just occurred to me as I read your post a second time through..."some" cards are doing this on a 24 up file? I recall having a similar issue with a client and it turned out the print engine was not at fault, though of course, in your situation, this may not be the problem...but still worth a look.
          It is likely the printed document itself. File corruption when being sent to the queue. Resend the job is one approach. Another is to save the file to PDF (in 24up) and print as image when sending. Use another graphics program to render the file and print. Use another PC.
          Further tests can be done through tech rep mode to eliminate the engine. In tech rep, test pattern output....
          Set all colours at 255, and select pattern 16. Test on light and heavy stocks....if there is a problem with the print engine, this test will show it with a vengeance.
          Might be firmware or the PRCB is failing then. Firmware should be at v60.
          If registration is fine on light stock, it should be fine on heavy stock too. Belt and drum speed are adjusted based on that variance.
          Also, it could possibly be a problem with the fiery rip itself. To eliminate the fiery, create a print port on the client computer that will print direct, instead of the print or hold queues.
          ---Groucho Marx
          • jhbtech
            • Oct 2010
            • 14
            The machine has become progressively worse over time.total counter is now on 1.1million clicks
            • Stirton.M
              • Oct 2009
              • 1804
              The machine is rated for 5 million...so still a long way to go. Most problems are fixable, or there are workarounds...this problem appears fixable...but then, I am not right in front of it to observe what is going on to know for certain.
              scans could help some just to verify suspicions.
              ---Groucho Marx
              • jhbtech
                • Oct 2010
                • 14
                the scans do not show the shift,so i cannot post that.but a better description is we printed a cmyk black text and the yellow has shifted about 1mm from the lead edge of image to the trail edge
                • jhbtech
                  • Oct 2010
                  • 14
                  the scans are not showing the shifting of the yellow and magenta.
                  • mr.propper
                    • Sep 2009
                    • 16
                    change the following settigs and your problem is solved.
                    The cause is a different Drumspeed when use thick paper.
                    It the same problem as "Drum drive error C-2211, C-2212, C-2213 or C-2214"
                    DipSwitch 21 - 6 and 7
                    Bit6 Bit7
                    0 0 : Default
                    1 0 : 0.1% up
                    0 1 : 0.2% up (recommended setting)
                    1 1 : 0.3% up
                    • jhbtech
                      • Oct 2010
                      • 14
                      I am sorry but I did that already
                      • HORSE
                        • Mar 2008
                        • 185
                        jhbtech if you find out how to fix it be sure to let me know, I have about 300 machines doing what you described.
                        Laughing......
                        • jma676
                          Expert Tech
                          • Mar 2009
                          • 323
                          Hi Horse, but I think that maybe I'm confused, but you have one of these last bulletin troubleshoting, as the friend says: "Color Are Shifting" did not clearly describe the problem but .... I think he means that the color is changing within the same impression.
                          As described in the Bulletin: "Banding of Halftoning" can be this... the problem.
                          "as they say: with a sample will be easier"
                          In terms of overall image problems can be solved in the majority, many of these arise from poor control of Machine, you should carefully review the stabilization control in all its possibilities and find the problem there, of course ... Bizhub consumables must be in good condition.
                          Most of the bulletins describe how you can solve these problems, but well this is funny, it is only an approximation of what actually happens in most cases I use the Bulletins only to find that parts have been modified or which functions have been added (SW), then use these "but" with my own discretion.
                          I don`t travel to Australia usually, "but 300 machines", let me know and we will gladly be organizing everything to be there and would help you personally.
                          • mr.propper
                            • Sep 2009
                            • 16
                            • jma676
                              Expert Tech
                              • Mar 2009
                              • 323
                              Originally posted by mr.propper
                              I think jhbtech mean this effects.
                              well mr.propper , as seen in this sample, seems to be a clear problem of color registration control, you can choose a precision color registration control .-
                              Well if you look carefully ... seems that for some colors the Main Scan problem and for others, Subscan.
                              As you were saying before: Correction of Drumspeed control can affect, although this would be only in one direction: Subscan.
                              ▼: Main Scan.
                              ►: Sub Scan.
