I have a 950 with FS528 - PK505 ... Customer prints out forms on 8.5x11R, double side, two-hole punch on top.
The copier will give a false jam at finisher J72-17 when you run two copies in the mode above. If you run 3 or more paper will be stuck inside unit which is why we run 2 copies only. You can run any other combination i.e. 8.5x11 - double side - three hole punch - two hole punch and will never jam. But if I run the unit in the above mode it will jam.
The following items have been replaced - FNS Drive Board (Twice) - PK unit and drive board - PRCB - Relay wire for exit actuator - exit actuator and sensor - entranced sensor for FNS - Actuator for adu unit on turnover section. There are some notes about firmware but it does not apply to this finisher only FS-611.
Have anyone else ran across this?
