Di450 - black display, no fans etc
  • Toner Boy
    • Aug 2007
    • 365
    We had recently replaced the fuser drive clutch (back panel). One week later the machine won't power up. Power switch won't flip all the way on, power activity lights are active on the main pwb and scanner control?, no fans, no engine cycling, nothing. Any ideas? Voltage at AC outlet is 117V. We also pulled the fuser out and tried it, no luck.
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    Go back to that switch, it could be bad. I have had to change them.
    • Toner Boy
      • Aug 2007
      • 365
      thanks, we'll try and hunt down a switch for it, maybe off a EP1083 - think its the same as the analogs.
      • Downunder
        • Aug 2007
        • 174
        it could be the main board or if my memory is right there is a small board in close proximity to the power plug on the side of the machine(exit end) could be that.
        • Darren King
          copiertech
          • 652
          I would check for a pinched wire somewhere around the fuser drive assembly
          Hope this helps
          Darren
