PK-517 Problem
  • agudmove
    • Jun 2009
    • 70
    PK-517 Problem
    PK-517 fitted in an FS-527, on 2 models, 452 + 652. All set up as per instructions, in this case 2/4 holes. Problem is, when you ask for 2 hole punch you get 4, on both model machines.!!! Anyone help
  • ep@ethos
    • Mar 2008
    • 7
    PK-517 makes 4 holes even when requesting 2
    Hi there,
    Did you find a solution to the problem/ Have fitted a same to a C360 and getting the same problem!
    • agudmove
      • Jun 2009
      • 70
      I looked at the Product Guide, and it states, 4 Hole Fixed Punch. So that's good enough for me. Salesman should have done his homework first!!
      • kingarthur
        • 1385
        As far as I can remember, 4 holes are for europe & 2 holes for usa, however we have "converted" them to 2 holes by dismantling & remove the 2 outer pins......but this has been at the customers risk...they sign a disclaimer first
