Keep overtoning after about 20k and have replaced developer & drum twice; and recalibrated drum percualirty adjustments setsup fine. Replaced toner control board. Checked developer augers, gears, and toner augers can't find anything wrong. Any suggestions Anybody???
Konica 7165 overtoning
Tags: 7165, adjustmen, attatched, collector, countermeasure, dev, developer unit, exposed, failure, grid, konica, konica 7165, modify, overtoning, wrong
random
random
Well that machine does not have a toner density sensor so it gets the available density from doing a patch test on the drum. You will have to go down the route of checking to see if this working correctly I guess. For example is the patch sensor stuffed, toner control board faulty etc. You could compare the outputs in I/O's with the DI.
Make sure the image is exposed correctly in the area where the patch sensor is reading, for example, for some reason there could be a light band in the patch area causing the machine to over compensate and overtone.
From memory I think you can adjust the toner density in the tank and patch density with dip switches.
All I can offer really.Comment
LooksBack
7165 Overtoning
Had a leaky developer unit cause this once. The toner mists out the ends and coats the sensors under the unit and it all goes downhill from there. Didn't notice the developer unit leaked because there was alway toner everywhere.
Good luck!Comment
I have numerous DI 650's with the same problem, all in all this is probably the dirtiest running copier ever. I really do dislike this pig and can offer you no fix what so ever other than you can adjust toner drop through the soft switches. I think I remember seeing a thread here giving exact procedure for making this adjustment.Comment
7165 overtoning
as you have changed toner c.b. then that cannot be scratched and all along this area is cleaned?much obliged peterComment
7165 overtoning
correct dev?
much obliged peter
Will
Of course I used the correct developer. I've gone in and cut back the adjustment in 25 mode for toner density and developer density soft switches and will continue to run and see what happens in the next 10-20k copies. Didn't adjust the one for image write density.Comment
Try these settings.
7155 - 7272 Background, Toner, Developer Spill Countermeasure Charges7155725571657272Clean optics and drum carriageCharge134134140146Check developer bias bearring install mod if neededTransfer100100100100Modify Developer bias bearing with p/n 090075530 see attatched pictureSep A.C110110130150Set chargesSep D.C105108115125Balance and set LD1 & LD2Grid113114115117Set all drum pecularity adjustmentsTGR0000Set dipsw 23-3 and 27-0 to 1 (Konica recommendation)Dev Bias187184182185Make sure 23-2 is set to 0 to prevent failure codesComment
wrong dev/toner
background/gritty line at front end is sometimes found to be charge grid too close to drum and is best solved by removing the grid cleaning pad completely,and alo cutting the spark arrester shoulders back by1 or 2mm
,this has been done toapprox 80 machines so far with good results
