ineo/Bizhub C/+ 450 calibration..
  • inutelkamo
    • Jul 2011
    • 143
    Good day..
    Any one encounter this type of problem in C450...
    Im about to calibrate the unit..
    1st, i must print a calibration pattern to be scanned on flaten glass, i use A3 size..
    and okey, it prints..
    BUT, when i put it on flatten glass and scan the pattern this error comes out;
    "scanner error"
    or somthimes
    "stabilization NG"
    any one encounter this? or suggestions?
    Thx in advance..
  • kingarthur
    • 1338
    Re: ineo/Bizhub C/+ 450 calibration..
    go to page 296 ( chapter 10.4.6) on the Version 3 aug 2006 service manual & adjust the scan area....i had the same problem on a C352
    • inutelkamo
      • Jul 2011
      • 143
      aw... didnt notice that....
      but when photocopy function is used, its all okey!
      is it same with you still?
      • kingarthur
        • 1338
        hi...its ok..i did the same as you & posted it on this forum, thats how i got the answer. When you scan & copy its fine...it's only when you or the customer carries out the gradation. good luck
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
