bizhub501 fax speed
  • digicor
    • Jul 2008
    • 1153
    [CQ] bizhub501 fax speed
    Is there a reason a 16 page fax could take 52 min? Is the speed on the phone line and the machine not set properly? Have not had this issue on the minolta. I have had issues with ricoh and older phone systems.
    Thank you
  • Albonline
    • Sep 2008
    • 1144
    Re: bizhub501 fax speed
    transmission rates fluctuate depending on line quality. that said is this unit on voip?
    • emujo
      • Jun 2009
      • 3009
      Set your scan default resolution to the lowest (100x200), under fax communication in service mode, set ECM to OFF, and coding to MH/MR. If this doesn't speed things up, check for low quality x-mission (noise). Emujo
