Konica c360 with c3923 code
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    A fellow tech has an issue with a Konica c360. It keeps throwing this code (c3923). reset code and 7 minutes later it codes out.
    As far as he remembers the fuser, power supply, and PRCB have been replaced. harness test good.
    Nothing in ssd solutions.
    Any body have an answer?
  • tbkarthic
    • Feb 2011
    • 66
    Re: Konica c360 with c3923 code
    what's status of fusing unit life?
    drugstore-catalog.com
      • 22997
      It reads as a pressure roller thermistor error. Is the thermistor in contact with the pressure roller? Is it making a connection to the main body (connector problem)? Is it making connection at the PRCB? Just 'cause it's new doesn't make the thermistor touch the roller. It's time to get out the VOM and start taking resistance readings back to the PRCB. =^..^=
      • cnswart
        • Oct 2011
        • 3
        Heater lamp inside pressure roller faulty
        • allan
          RTFM!!
          • 5462
          Manual also mention to check if the right side door is latching properly.
          So for that 7 minutes printing is normal?
          All the fuser temp settings on default?
          Whatever
          • cnswart
            • Oct 2011
            • 3
            My machine switched on and after 7 minutes it gives the code - after fault finding I found that the heater lamp was faulty - just do visual inspection or test resistance on lamp - that will quickly give you an indication
            • femaster
              • May 2011
              • 1477
              I'm hoping they have already figured this out since the question was asked over 8-years ago.
              • joaopauloooo
                • 44
                My C220 was throwing the C-3923 and was resolved after changing this little f**** from the fuser.
                  • 22997
                  That's a thermostat. It's thermal protection, with a metal disk inside that warps to break the connection when the fuser excess a certain temperature. If you remove it from the fuser and bang it against the table, sometimes it will reset.
                  • Synthohol
                    Certified Konica Expert
                    • 5793
                    i had a video of me resetting one 3 or 4 times against the table.
                    they are re-settable.
                    in the olden days we would put them in the freezer to reset. or hit 'em with an upside down aircan to freeze.
