konica minolta bh211 Machine powers on then cuts out!!
  • humpty dumpty
    • 29
    [Dead] konica minolta bh211 Machine powers on then cuts out!!
    I have a problem on a bh 211, The machine powers on then cuts out straight away, i have changed the fuser and interlock switch. any ideas guys!!!
    thanks in advance
  • humpty dumpty
    • 29
    Re: konica minolta bh211 Machine powers on then cuts out!!
    My good old diamond geezer suggested it may be DCPS so have ordered it!!!
    will let you know outcome but i recon it may be this as he is an old fossil!
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • humpty dumpty
        • 29
        I don't need a manual!!
        • Hansoon
          • Sep 2007
          • 3391
          WTF is DCPS?? Something like PMS or CRS?
          Hans
          • juve
            • Dec 2012
            • 86
            does it turn off immediately after switching on?if no,check the auto shut off time.if yes,first i will go for fuse(but u changed it) then i will check for a short in hv.try to check also the flatcable of the scanner were it twists,maybe there is a thorn and makes short,and also check for a nibbled wire from a rodent(mouse),once i had this problem and found a wire scratched by mouse which was shorting!
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              stupid question, but does it shut off instantly with the side door open too?
              • EarthKmTech
                Step aside, noob
                • May 2009
                • 2139
                Hans
                sounds like canon talk to me, for DC power supply
                • mick o connor
                  • Jan 2013
                  • 9
                  hi, something to check, is there a PF 502 fitted????, In the distant past I had a customer move a similar machine to a new office, lifted m/c off cabinet, pulled the wiring loom ,
                  when they reset the machine on the paper unit the broken loom shorted of the metal. lets know how you get on, thanks Mick
                  • humpty dumpty
                    • 29
                    Thanks for all replies I am hoping to visit this mc tomorrow weather permitting! Will let you know my findings cheers!
                    • humpty dumpty
                      • 29
                      [QUOTE=EarthKmTech;336325]stupid question, but does it shut off instantly with the side door open too?[/QUOTE
                      the machine powers of only when you shut right hand door or front door !!!]
                      • EarthKmTech
                        Step aside, noob
                        • May 2009
                        • 2139
                        then yep, it sounds like a fusing malfunction, although I think there are a few other critical errors that will cause the machine to automatically switch off (this in itself is not a fault, they are supposed to do that when a high level critical error is detected) Consult the service manual.
                        Usually there is an error code displayed for at least 1 second before the automatic shut off.
                        • mrwho
                          Major Asshole!
                          • 4299
                          Turn the machine on while pressing the stop key.
                          Mascan42
                          Ibid
                          • humpty dumpty
                            • 29
                            Ok I have been to machine, changed Dc power supply, fuser, rear door interlock switch, I have turned on machine whilst holding stop, the pf wireing was caught but not the issue as unplugged PF completely.
                            I have now ordered front interlock for rhs door and interlock switch for front door and also main on/off button switch and Loom.
                            Any other suggestions guys and gals?
                            • EarthKmTech
                              Step aside, noob
                              • May 2009
                              • 2139
                              What is the code that flashes on the LCD prior to it turning off ?
