Bizhub PRO 920 Jamming continuolsly
  • Mattdlam
    • Apr 2013
    • 32
    [Jamming] Bizhub PRO 920 Jamming continuolsly
    Hi there,
    Need some advise please, I have a 920 that is jamming non stop paper does not even exit on the finisher, paper stops on the M12 Cover as it enters the ADU, just after passing the transfer\separation as it enters the fuser and underneath M11 on both sides, I have changed the rollers cleaned out the machine but am just looking for guidance on which clutches or gears I need to clean or lubricate.
    Thanks in advance.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Bizhub PRO 920 Jamming continuolsly
    Paul@justmanuals.com
    • methogod
      • Dec 2008
      • 921
      need a bit more info..
      what are you printing?
      what weight paper?
      what path ? face up face down, duplex?
      etc...
        • 23010
        jam codes? =^..^=
        • Mattdlam
          • Apr 2013
          • 32
          what weight paper?
          etc...
          I am printing textbooks on A4 PLAIN 80GSM, FACE UP Duplex.
          Jam codes are always coming different, J51-01, J72-17,J14-01,J94-02, J7216
          • methogod
            • Dec 2008
            • 921
            run face up no duplex see if your codes go away.
            if they dont its your ADU board.
            if they do go away you need to clean the hell out of the machine.
            J51-01 and J14-01 are jaming out of trays
            J72-17 J72-16 are timing after the fuser
            Swap adu board with another machine to test.
            • Mattdlam
              • Apr 2013
              • 32
              Thanks will try this and feedback.
