C454 C9403 code with dual scan adf DF701
  • faultman
    • Nov 2009
    • 20
    Hello guys
    anybody come across this fault code with the dual scan document feeder, any information would be appreciated.
    thank you
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: C454 C9403 code with dual scan adf DF701
    Yes,
    Several times.
    And after changing everything the service manual suggests it was the black moulded display port data cable from the CIS in the ADF to DSCB in the back of the machine.
    internal breakage occurs at the stripped and clamped down section next to the CIS.
    • faultman
      • Nov 2009
      • 20
      Originally posted by EarthKmTech
      Yes,
      Several times.
      Thanks for the information, the cable you talk about.... Is it the one that looks a bit like a USB cable. Is it usually just this part that causes the fault code.
      thank you
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        yes, thats the one, and its black.
        That's what it's been in my experience and given that its cheaper than most parts the service manual suggests its worth a try.
        • CraigW
          • Dec 2010
          • 417
          Got one giving 9403s a lot.
          Going to give it a try....fingers crossed !!
          • CraigW
            • Dec 2010
            • 417
            Not too bad all in all. The manual has the procedure but left out the steps about removing the washered screws to be able to raise assembly, and access the screw for the white clamp.
            Thanks for all the help on this issue provided.
              • 22999
              This was my experience:
              http://www.copytechnet.com/forums/ko...fa1-c6753.html
              • CraigW
                • Dec 2010
                • 417
                We tackled the cable replacement and all is QUIET.
                Thanks for the info on the cable and the tips.
                • EarthKmTech
                  Step aside, noob
                  • May 2009
                  • 2139
                  I did another one today.
                  every one of those early fat cables will fail eventually it seems.
                  1 is kept in my car at all times, its slowed down these days though since the standard fitment of the thinner cable from the factory.
                  • Rylac
                    • Feb 2015
                    • 26
                    Thank you so much for putting this info EarthKMTech!!
                    • EarthKmTech
                      Step aside, noob
                      • May 2009
                      • 2139
                      Still the odd fat cable machine out there - I changed another one last week on a machine with 1 month contract left!
                      Soon all of this will be a distant memory.
