Bizhub C280 (CQ)
  • fancheta
    • Oct 2013
    • 30
    [CQ] Bizhub C280 (CQ)
    I'm having problems with a C280 machines for a few days now. The problem is when a color copy or color print would come out, you can see a very faint background of yellow. If you look closely at the background, you can see lines. The image units have been replaced, and transfer belt roller cleaner have been vacuumed from excess waste toner. Also to point out, after a copy, I noticed that there is yellow toner that is hazed on the transfer belt. Any ideas?
    • 22999
    Re: Bizhub C280 (CQ)
    Have you done the gradation?
    • fancheta
      • Oct 2013
      • 30
      Yes I have
      • RRodgers
        • Jun 2009
        • 1947
        Yellow is the first color to be put on so it will be the last to come off. (the transfer belt) So I would imagine that some would be left on the belt after transfer to paper. (I believe it goes YMCK on that box)
