Bizhub C451 print problems in thick mode
  • happyhour
    [CQ] Bizhub C451 print problems in thick mode
    Hello,
    I need help with printing in thick paper setting. This problem did not show up until today and seems to get worse the more I print. It does not show up in plain paper setting on plain paper. I have attached 2 pictures, one printed on thick 3 setting with 80 lb cover and the other on plain paper setting with plain paper. I ran the color test in service mode which was done on plain paper and did not see any problems. Even when printing a picture on plain paper setting, picture looks good. Printing the picture on any thick setting, I get the same problem in the same area of the page.
    Also, prints with same problem when making a copy. Please Help!
  • irokkas
    • Oct 2012
    • 18
    Re: Bizhub C451 print problems in thick mode
    Originally posted by happyhour
    Hello,
    Hello, did you find the solution on this, because I have same problem with a c452.
    Thanks in advance
    • tsbservice
      Field tech
      • 7911
      Thanks in advance
      Ouch, what a waste of time.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4524
        Thanks in advance
        You might need a fuser unit. If you run a lot of thick stock the fuser units life is shortened considerably, especially with the older models.
        • irokkas
          • Oct 2012
          • 18
          Tried another one. Nothing changed. It could be from transfer belt or transfer roller? I am not familiar with these machines. Mostly Ricoh. Thanks again
          • copyman
            Owner / Technician
            • Sep 2005
            • 4524
            Wouldn't be the transfer belt or roller if only one color is affected. If only one color than I would look at that color image unit being low on developer.
