Bizhub C652 - 1102 Jams
  • MVPunisher
    • 209
    So this is kind of a funny issue to me. Maybe someone has seen it before. I have Just tray 1 jamming. 11x17 feeds fine, all day. Letter size paper though Jams every 2nd or 3rd page. The paper gets out of the tray but just stops in conveyance.
    I have swapped the clutches out thinking one sticking or something (wouldn't explain why 11x17 runs all day). I did rollers and torque limiters, but they don't make sense because the first sheet makes it through the machine every single time, and again the 11x17 does also.
    Also tried Firmware. This happened to our machine in the shop sometime back but the solution was keep 11x17 in that tray (lol). Now I have one in the field doing it so I have to figure it out.
    Definitely seems like some sort of timing issue. Any help if someone has had this happen would be appreciated. Thank you.
    Matt
  • MVPunisher
    • 209
    Re: Bizhub C652 - 1102 Jams
    Justmanuals.com
    go ahead carry on
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • occus
        • 339
        Have a look on my thread "10-02, 11-02 Jams" bizhub C452
        There is a vertical transport clutch, but in the manual it calls only "gear"... is as black gear with a white plastic inside and a spring... mounted on the drive of 1.paper vertical transport.
        good luck!
        • shorty
          • Mar 2021
          • 1
          good luck!
          Hello man , sorry is this the "gear" ?
          gear? - Album on Imgur
          • emujo2
            • Mar 2017
            • 1579
            Do you realize your are jumping onto a 10 year dead thread?
            • Synthohol
              Certified Konica Expert
              • 5910
              never gets old (unlike the thread )
              • femaster
                • May 2011
                • 1527
                And to answer your question on this dead thread, no, that is a one way bearing, not a gear.
                Based on the description in the post you quoted, the "gear" you are looking for is a spring clutch. If you need any further help, start a new post.
                • Walterj
                  KONICA MINOLTA
                  • Jun 2017
                  • 89
                  • Synthohol
                    • 5910
                    Translated
                    QUOTE = MVPunisher; 393227] So this is a fun topic for me. Maybe someone has seen it before. I only have tray 1 stuck. 11x17 eats well, all day. Although letter size paper jams every 2nd or 3rd page. The paper exits the tray but just stops during transport. I changed the clutches thinking one is sticking or something (wouldn't explain why 11x17 runs all day). I did rollers and torque limiters, but they don't make sense because the first sheet goes through the machine each time, and again the 11x17 does too. I also tried Firmware. This happened to our machine at the store some time ago, but the solution was to keep 11x17 on that tray (laughs). Now I have one in the field doing it, so I have to figure it out. It definitely looks like some kind of timing issue. Any help would be appreciated if anyone has had this happen. Thanks. Matt [/ QUOTE
                    • acusso1234
                      Tecnico
                      • Dec 2008
                      • 250
                      ... In the minute that you're thinking of giving up, think about why you lasted so long ...
                      • tsbservice
                        Field tech
                        • 8076
                        Very old thread plus this guy knows KM stuff very well plus this machine is more than likely dead.
                        Please move on.
