C652 missing print
  • KEN
    • Feb 2011
    • 13
    [CQ] C652 missing print
    Hi
    i have problem with C652 ,the transfer belt and roller have been replaced but problem persists
    any help appriciated
    see attached image of C Y M K halftone images A3
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: C652 missing print
    you need to do the stop test to determine where the problem is actually occurring.
      • 23008
      Ditto that. Run those images ledger/A3, then pop the door open when it's just reaching the fuser. Logically it's got to be primary or secondary transfer. Does the developed image on the primary belt look good? Does the unfused image on the paper look good? =^..^=
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • RRodgers
          • Jun 2009
          • 1947
          Is your waste box full of gritty stuff?!?! Looks like you've lost dev on ALL your IU's. How are the HV connections on the machine? I'd check them and be sure that they are clean. I'd be willing to bed you might have a HV unit that is going out and pulled dev.
          • KEN
            • Feb 2011
            • 13
            Fixed should have spotted it sooner
            rear arm of transfer roller holder broken underneath
            • copier tech
              • 8144
              I had one of those break last week, I repaired the broken part with a cable tie. What item did you order to fix this?
              • KEN
                • Feb 2011
                • 13
                Hi
                The rear arm is A0P0710501 and the one it goes through is 4036471201
                • copier tech
                  • 8144
                  Originally posted by KEN
                  Hi
                  Cool thanks, how easy is this part to replace BTW?
                  • KEN
                    • Feb 2011
                    • 13
                    Easy to fit 1 circlip on arm and 1 spring on part it goes into
                    • copier tech
                      • 8144
                      Thanks, i'll order this part & replace next visit
                      • EarthKmTech
                        Step aside, noob
                        • May 2009
                        • 2139
                        these seem to snap all the time, I carry them in my car - still happens with the 654e / 754e too.
