Konica Minolta Bizhub C353 Print Stop
  • Soteria17
    • Oct 2011
    • 16
    This week I had a Bizhub C353 that everything you try to print (Copy, Print, Fax) goes to the job que and the job instantly comes up as "Print Stop". I can scan to desktop with it though. I talked to some other techs and they said it was the fax card so I checked it and reset it but nothing. Any suggestions?
  • JustManuals
    • Jan 2006
    • 9838
    Re: Konica Minolta Bizhub C353 Print Stop
    Paul@justmanuals.com
    • nvram
      • Jul 2009
      • 40
      you're image unit life needs setting to non stop.
      Stop 0 0 stop 0 1 stop 0 C
      • Synaux
        • Mar 2012
        • 1224
        Or there is another internal error, do you see any alerts on the panel?
        I have had to flash the firmware on some machines just to get the errors to show (IU error and P** codes normally follow a flashing).
        • kingarthur
          • 1301
          Totally agree with nvram, it's your IU stop settings
          • vamoursly
            • Sep 2011
            • 273
            Hello
            New to the Konica world
            To verify is this done by changing a software switch, or a setting in service mode 2
            Just reading through the SM, a little confusing
            Thanks for your input
            V
            • copier tech
              • 8101
              Yes you need to change some software switch settings but you'll need to flash the special firmware first.
              for a quick fix you can buy the drum chips to fool the machine that you have fitted new image units.
              • emujo
                • Jun 2009
                • 3009
                Re-chipping is a bad idea...IMHO...you are telling the MFP that these are new IUs, CQ problems will result. If you are a trained KM tech, you can find the PPLM firmware on the SSD web site. There are a few soft switches to set, but now your IUs, X-fer belt can run until failure and the MFP will accurately adjust any bias voltages correctly based on the number of revolutions. EMujo
                • vamoursly
                  • Sep 2011
                  • 273
                  I am working with the bizhub 224e in this instance, still flash the latest firmware, then go into service 2 alter the settings, then change the relevant software switches?
                  V
                  • CompyTech
                    Super Tech
                    • Feb 2011
                    • 706
                    V
                    No need to on 224e... The settings should be in Unit Change under Service 2 and the Stop 0 C.. KM added these features in on the 4 series. By default the machine should Not stop at EOL on consumables, however the message should display. Likely someone at setup turned them all off or something.
                    • rrrohan
                      • Sep 2011
                      • 1977
                      have ou checked the consumables count to confirm that end of life is in fact why its not copying?
                      • pdcopiers
                        • Jun 2014
                        • 15
                        Hi guys, I working in a Bizhub c353, the machine was working good, but we unplug it to moved the machine few steps and when we plugged it back there has not lights on the network card. I able to chance ip but is not respond at all. Please help, thank you
                        • copier tech
                          • 8101
                          After you power off the machine can take a while for the network card to resond, try setting IPV4 to DHCP see if it picks up an IP
                          • pdcopiers
                            • Jun 2014
                            • 15
                            Thank You for your quick response, I already try to setting IP to DHCP and it's change to crazy numbers, but nothing good. And also I initialized the machine, but still l don't have any Lights from the network card. The machine has been connected for 5 hours.
                            Any other solution?
                            Thank You again
                            • nvram
                              • Jul 2009
                              • 40
                              Any other solution?
                              Thank You again
                              Hi, Did the machine return an IP address starting 169.254 if so the nic has gone to sleep, it is possible to awaken it by changing the network speed in detail settings of the network setting tab.
