C3BO2 in c452
  • a-copy
    • 8
    [Error Code] C3BO2 in c452
    Hello,
    I have this code in c452, any ideas for that?
  • copier tech
    • 8174
    Re: C3BO2 in c452
    Most likely failed fuser unit
    • JustManuals
      • Jan 2006
      • 9838
      Re: C3BO2 in c452
      Paul@justmanuals.com
      • Synaux
        • Mar 2012
        • 1224
        Re: C3BO2 in c452
        In addition to the fuser this might help TAUS1000978EN , C-3B02 or C-3B03 error code.pdf
        • hotfuser
          • 180
          Re: C3BO2 in c452
          This problem is usually the IHPU failing. 9 times out 10 it is that but if it persists change the coil.
          • Damien Bates
            • Jul 2023
            • 3
            Re: C3BO2 in c452
            If you have tried troubleshooting the printer and the problem persists, it may be necessary to replace the IHPU. This is a common issue with printers, and replacing the IHPU is a relatively simple repair that can be performed by a technician.
            In some cases, if the problem continues even after replacing the IHPU, it may be necessary to replace the coil as well. The coil is another component within the printer that can cause issues if it is malfunctioning. slope game
            If you are not comfortable performing these repairs yourself, it is recommended to contact a certified technician who can diagnose and repair the issue for you. By doing so, you can ensure that your printer is functioning correctly and avoid further damage or issues down the line.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4723
              Re: C3BO2 in c452
              You do realize the OP is 9 yrs old from 2014....
              • femaster
                • May 2011
                • 1514
                Re: C3BO2 in c452
                Slipped in a SPAM link I see. I had you pegged from the start. ChatGPT using SPAMmer is all you are! Piss off!
