BizHub C364 installing firmware
  • copier tech
    • 8172
    #16
    Re: BizHub C364 installing firmware
    Originally posted by Helge_Muc
    Hi,
    i am struggeling since 2 years to get the C364 to send Scan to email (Office 365 or gmail available).
    HAs anyone the latest (german) firmware available?
    Can anybody give hints for the Scan to email?
    Thanks so much & Kind regards from munich
    Helge
    There is version up firmware available this upgrades the C364 to a C364'e' SLL/TLS is sported allowing O365 & gmail compatibility.
    We can supply should you decide to go down this route.
    • Helge_Muc
      • Nov 2019
      • 6
      #17
      scan to FTP?
      USB?
      No, no option in my case!
      • Helge_Muc
        • Nov 2019
        • 6
        #18
        Will be happy to try. Is the copier's language still german?
        Helge
          Konica Minolta bizhub C364 Printers and MFPs specifications
          supposedly BOTH C364 / e models have usb
          is it disabled?
          • Helge_Muc
            • Nov 2019
            • 6
            #20
            No, sorry. USB works but it is no option for my case.
            The person who should receive the Scan is not in the same building and FTP/SMB is also no option as i needed to deliver the Scan as PDF to mobiles phones.
            • copier tech
              • 8172
              #21
              Helge
              Updating the firmware wont change the language.
              • Helge_Muc
                • Nov 2019
                • 6
                #22
                How to get the Firmware and any Special instructions or as usual?
                • tsbservice
                  Field tech
                  • 8020
                  #23
                  You have like 3 ways imho:
                  1. Contribute here and wait for a member to supply you with files.
                  2. Pay and get Firmware and support from copier tech.
                  3. Go and ask elsewhere.
                  • copier tech
                    • 8172
                    #24
                    I'm assisting him, thanks.
                    • gere1
                      • Oct 2018
                      • 20
                      #25
                      Check that when the HDD was removed, the cable that has the door sensor for the firmware will also not be taken
                      Translated by Google I hope it is understood
                      • Kragox
                        #26
                        Hello.
                        I need newest firmware to this model with poliish language.
                        Can anyone send me link?
                        Thanks!
                        • KaliDesigns
                          #27
                          Hi everyone. We just got this printer from another company that went out of business. I'm fairly knowledge at trying to fix them myself but having some difficulty with duplexing.
                          Tried some of the fixes here and would like to also update the firmware but do not know where I can find it, I have googled with no luck. Last time this was serviced by Konica was back in 2016.
                          Any help would be appreciated.
                            as Copier Tech stated " Firmware doesn't change the language "
                            that is done thru the cntl pnl.
                            • srvctec
                              Former KM Senior Tech
                              • Oct 2009
                              • 827
                              #29
                              Might want to start your own thread. What makes you think you need F/W? The last F/W for these models was January of 2014.
                              Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                              • tsbservice
                                Field tech
                                • 8020
                                #30
                                Ideally you call certified tech to do maintenance and troubleshooting after 4 years.
                                If you want to do it yourself much more info is needed as counters, error codes, parts life etc.
                                If you come solely for FW contribute and may have better chance someone have it for you.
