Konica press 1250 jam 2101
  • jaredfmn
    • Sep 2008
    • 25
    We have several 1250 and 1200 machines in the field jamming with 2101 jam codes. I have gone through the trouble shooting guide with little luck. Tried new transfer unit and cleaning unit. Full pms on all the machines with new drums and developer. If anybody has any ideas I am open to suggestions. They have the latest and greatest firmware as well.
  • jaredfmn
    • Sep 2008
    • 25
    Re: Konica press 1250 jam 2101
    Nobody???
    • cycle66
      • Jun 2014
      • 13
      Nobody???
      Have you looked at Konica's solution TAUS1001124EN?
      • blaze2000
        • Sep 2010
        • 232
        We are having that jam code on a new install as well. 58,000 clicks and 72 2101 jams. Information in bulletin 1124 didnt help. Including replacing jamb.
        • antone
          • Oct 2014
          • 344
          Try good paper 1051 1052 they all have this problem!!
            • 23009
            It just started on one of my 1052's. All paper sources are affected. The environment is 75F 44% humidity. The drum claws function normally and are recently replaced. The jammed paper frequently tries to follow the drum and flips over, entering the fuser upside-down. If you get the jammed page near the drum it statically adheres to the drum.
            I've come to the conclusion that we're losing separation voltage, and the paper is still statically attracted to the drum. I've tried a different transfer belt assembly, cleaned and greased contacts, DIPSW 51-1:1, 51-0:0, tried various transfer offset settings with no change. DIPSW 57-4 and 57-5 make no difference either way. We've got an HVT on order.
            Has anyone had any success fixing this? =^..^=
            • Synthohol
              Certified Konica Expert
              • 5846
              in paper tray settings, choose separation priority and i have also moved the drum claw solenoid so the claws have less clearance for the paper to get stuck in.
              but yes, better paper will help tremendously.
              • KM1Amsterdam
                • Jun 2014
                • 36
                Yes these two work the best. Check the drum claw solenoid in state confirmation, already had two dead ones.
                When replacing the drum claws clean the shaft en surroundings very thorough. Replace the springs.
                  • 23009
                  The drum claws are new and working properly. I'm disturbed that the jammed paper is not discharged. If the paper does not discharge, there's no way it can pass.
                  The HVT on the imaging drawer did not help. I also imported the machine settings from a year ago. At this stage it will not pass a single page of any type of paper. =^..^=
                  • andyf424
                    • Jun 2013
                    • 126
                    I've got a 1250 doing this also, cleaned and rebuilt the separation claw assembly with new claws/springs, also set lead edge transfer to "value separation". Customer is running really flimsy paper and in portrait mode and it's a humid environment, basically a perfect storm. I've even slowed the speed down in process mode with no help.
                    Is it Friday yet?
                    • allan
                      RTFM!!
                      • 5462
                      Is it Friday yet?
                      Could try an HT-505 on one of the PF trays. That should keep the paper dry
                      Funky paper should be used in tray 4 where the paper does not get stressed out too much.
                      Whatever
                      • andyf424
                        • Jun 2013
                        • 126
                        When in doubt, try tray 4, still jams though. I flipped the drum claw spring on the end of the shaft that actuates the drum so the claws were up at all times but it still jams.
                        • allan
                          RTFM!!
                          • 5462
                          Where does the paper end-up?
                          Whatever
                          • MVPunisher
                            • 209
                            I battled this exact issue with W.B. Mason paper on 2 951s right next to each other. Could barely get a copy out of either machine. I Read on here that this machine is very picky about what paper it likes. Brought a carton of Universal paper in and ran the entire carton between the 2 machines without 1 single jam. Just saying. The paper wasn't any heavier it was just another brand.
                            • andyf424
                              • Jun 2013
                              • 126
                              Stopped right at the drum, paper is trying to wrap around the drum but the claws are stopping but its still jamming. Took the customers paper and tried to run their job on our showroom 1250 with 20k on it, exact same jams. Then we tried running it on a c1085 with +15 k on and we still got jams at the secondary transfer. Paper paper paper.....
