Konica press 1250 jam 2101
    • 22934
    #16
    Re: Konica press 1250 jam 2101
    On Friday I installed the HVT and some odd 6M PM parts that were not in-stock for the PM. I got perhaps 6 pages to pass (and 50+ jams).
    When I showed up Monday with the Team Leader, there were 2K in the elevator tray and not a single jam. Team Leader looks at me (why are we here?).
    I started out thinking it was the paper, then tried other things. Now I'm back to the paper. =^..^=
    • Arcadian
      • Feb 2010
      • 218
      #17
      I HAD this error for a while its was one of the one way gear in the exit area of the copier near the fuser also there a one way gear on the fuser that might be slipping!
      i changed two one way gear in the exit area and the error went away..
      • allan
        RTFM!!
        • 5459
        #18
        I also had this same issue with 2 B1250 machine next to each other. J2101.
        The operator knows not to phone for that, Changing the paper fixed it every time.
        Found that any distortion on the paper edge would cause that, even on nice and thick 90-100 GSM paper with poorly cut edges.
        But if this machine runs it runs. Those 2 machines made 22Mil in a year and a half.
        Whatever
          • 22934
          #19
          Originally posted by Synthohol
          in paper tray settings, choose separation priority and i have also moved the drum claw solenoid so the claws have less clearance for the paper to get stuck in.
          but yes, better paper will help tremendously.
          I may have had some success today using this approach. I measured a gap of 1.25mm between the tips of the drum claws and the drum. When the solenoid is actuated the tip gets very close, but does not touch the drum.
          I started by forming the rods that support the drum claw assembly up, unit the claws touch even before the solenoid is actuated. With the drum cleaning unit removed I nudged the rods downward a little at a time unit I got a 0.25mm gap at the front and rear claw tips. You can see pretty well with the cleaning unit removed. Now, when the drum claw solenoid fires it only has to move 0.25mm.
          Everything about the drum claw assembly is so malleable/flexible, that it's difficult to get consistent results. =^..^=
          • mx6turbo89
            • Oct 2013
            • 154
            #20
            I have had this problem with several different boxes and every time it has been the transfer offset adjustment that has fixed it. It can be adjusted per tray:
            J-2101
            [Symptom]Drum wrapping jam occurs when using specific paper.
            [Cause]Transfer value and transfer timing is inappropriate.
            [Solution]Change the transfer current value in the MACHINE screen as follows. (Transfer leading edge 1, 2 only)[Tray Setting]-[Change Set]-[Process Adj.]-[Transfer Offset Adj.]Step1Increase offset value at leading edge1. (by 10 step)*: When belt separation and leading edge image quality were deteriorated, decrease the value.Step2 (If Step1 is not effective)Decrease the value of the leading edge1 and 2.*: When the transfer fails at the leading edge section, increase the value.Then, register the name of the paper. (Can be register up to 100)
            • Albonline
              • Sep 2008
              • 1132
              #21
              The drum claws are new and working properly. I'm disturbed that the jammed paper is not discharged. If the paper does not discharge, there's no way it can pass.
              The HVT on the imaging drawer did not help. I also imported the machine settings from a year ago. At this stage it will not pass a single page of any type of paper. =^..^=
              ensure drum ground path, have seen this kind of thing in may different models, usually ends up being static buildup due to poor grounding.
              • allan
                RTFM!!
                • 5459
                #22
                Found a new reason the machine would give J-2101 that and J-3111(skew sensor jam).
                If tray 1 and 2's feed tires are done it makes a dent in the paper that would catch under the drum.
                Had that jam while i was working on a machine next to it it would jam every 100 pages or so.
                Changed the feed tires and the problem was gone more than 10000 pages printed!
                Whatever
                  • 22934
                  #23
                  What kind of usable life do you get from the standard rollers? The stated yield is 500K, but about 300K is about all I can expect. The orange neoprene rollers seem to wear more slowly. The problem is that there are more jams, even when brand new. I won't be installing any more of the orange rollers. And if you add the pickup weights you'll get less than 200K, and the rollers wear unevenly.
                  Thanks for the information. =^..^=
                  • allan
                    RTFM!!
                    • 5459
                    #24
                    Those big grey ones? A4EUR714## ?
                    Got more than the yield. 500K + that assembly does feel a bit flimsy?
                    I changed them on a total page count of 12M and a feed count of 8M for the first time.
                    Have to say the wear looked minimal and even. I compared the old ones to the new ones while changing them out.
                    Every thing one these machines goes well past.
                    Got the air suction feed units on there PF-703 that thing is rock solid, so tray 1 and 2 shares only a little of the load.
                    The orange ones would do about 250K from my experience the ones on the B423?
                    I always change all 3 at the same time but its then only the separation roller that was badly worn out.
                    Those grey ribbed pick up tires works really well i leave them on there for a second time.
                    The B601 machine roller would do 250K+.
                    Whatever
                    • cgw71
                      • 15
                      #25
                      J-2101
                      Ok, I am going to give this a try. We have changed transfer voltage for the tray already and adjusted the solenoid position at the same time about 6 weeks ago. It runs well and then occasionally (sometimes after thousands of copies) it will do it again. And it only does it on 8 1/2 x 11 paper. Any larger sizes and it works perfectly. I am guessing the extra weight from the longer sheet is enough to pull it off the drum. Whatever is wrong is just barely wrong. I'll post the results of this. Feels like KMinolta should address this a little better.
                      • cgw71
                        • 15
                        #26
                        Originally posted by jaredfmn
                        We have several 1250 and 1200 machines in the field jamming with 2101 jam codes. I have gone through the trouble shooting guide with little luck. Tried new transfer unit and cleaning unit. Full pms on all the machines with new drums and developer. If anybody has any ideas I am open to suggestions. They have the latest and greatest firmware as well.
                        If you have access to the Konica site there is a Troubleshooting guide accessible on the SSD page that was released in July. It has several suggestions for dealing with a J-2101. Many have been mentioned here already but it is worth looking at.
                        • mx6turbo89
                          • Oct 2013
                          • 154
                          #27
                          KM does have a lot of write-ups for this problem. This guide has been helpful for me (particularly the last page): https://www.dropbox.com/s/tn7v8wcm45...ollow.pdf?dl=0
                          • tradewynnes2
                            • May 2009
                            • 7
                            #28
                            J-2101
                            I am also having these issues with a 1052 and I believe these adjustments will work, but the problem I have is that all of my high voltage adjustments are grayed out. Does anyone know where to turn them on? I'm sure it is a DIPSW, but I don't have time to look at every one until I find it.
                            • D_L_P
                              Self Employed
                              • Oct 2009
                              • 1196
                              #29
                              Just throwing this out there but HV is modified by the machine depending on humidity. Check or replace the sensors if they report 0% humidity. IIRC the 950 had a thermistor below the transfer/sep unit. Replacing that thermistor fixed some weird cq/codes. It's a shot in the dark but maybe due to that sensor the machine thinks it has to lower the separation voltage.
