bizhub c224
  • bineeshgeorge
    • Jul 2009
    • 107
    bizhub c224
    Hai dear friends,
    One of my bizhub c224 gives fade copy after one month rest. Before one month rest it was no problem.
    It gives very fade copies and no yellow,other colours are present ,but very light.Gradation is not possible because it shows p6,p7,p8,p9,p21and p28. This machine run only 40000 copies. I had check all drum units ,developer units and transfer belt but no one see abnormal.please help me with your valuable suggestions ...
  • RRodgers
    • Jun 2009
    • 1947
    Re: bizhub c224
    Originally posted by bineeshgeorge
    Hai dear friends,
    Most copier while they have a max number of copies they'll do a month also have "at least run this many" a month figure as well. I remember the C500, it was recommended that you ran at least 5000 copies on it a month or you'd have problems.
      • 22999
      Re: bizhub c224
      Agreed. We have customers that buy color copiers for 25K black and 500 color per month. The next time they want to do a big color job, the color developer is dead, and they complain: " ... but we haven't even used color!"
      Exactly. =^..^=
      • occus
        • 332
        Re: bizhub c224
        Check the toner value in DV. It should be around 7%...
        • support@itecgroup.com
          • Apr 2013
          • 16
          Re: bizhub c224
          Hi,
          Sounds to me like a HV problem. Test with another HV board. Should sort out this problem. Common problem on this models
          • copier tech
            • 8132
            Re: bizhub c224
            Have you cleaned the IDC sensors?
            Copier dont like not being used, Try cleaning them then running 50 or so colour duplex prints
            • bineeshgeorge
              • Jul 2009
              • 107
              Re: bizhub c224
              IDC Sensor cleaned.
