bizhub C220 - blue border at the lead edge when copying a green area
  • Laserbeam
    • Aug 2011
    • 152
    [CQ] bizhub C220 - blue border at the lead edge when copying a green area
    Hello,
    when copying a green area in duplex-mode, only the rear side shows a blue border at the lead edge (main scan direction). This effect only occurs on the rear side in duplex mode, the front side is perfect. In one-sided copy mode the result is perfect, too.
    It seems to me, that the transver of the yellow color is faulty.
  • Luther
    • May 2006
    • 682
    Re: bizhub C220 - blue border at the lead edge when copying a green area
    looks like it just happens on the lead edge, could be because curl in paper on 2nd side, try running it in heavy stock and see if it goes away, it will increase transfer voltage in heavy stock
      • 23009
      Did you notice the lack of yellow along the bottom of the image also?
      I'd run stabilization and gradation again.
      Transfer might apply if it was only flip at the trailing edge, but I think I see it along the bottom also.
      Is it any special kind of media?
      • B0265
        • Jan 2007
        • 718
        Try to change the paper separation adjustment for 2nd side to -1 or -2.
        • tech51
          • 846
          Had something similar to this, ended up being a faulty HV board.
