Bizhub 223 snake alike patern
  • ianferron
    • Jul 2025
    [CQ] Bizhub 223 snake alike patern
    I am having some intermittent snake pattern banding about 1 inch wide. Seem like a charge issue. Anyone had that issue? Anyone found a solution?
  • Blizzoo
    • Aug 2013
    • 608
    Re: Bizhub 223 snake alike patern
    Post a sample
      • 23008
      Have you done anything? =^..^=
      • Hansoon
        • Sep 2007
        • 3384
        Well...., he made a post about it.....
        Hans
        • habik
          • 2013
          Well If you have maglev looking like snake you may have dodgy toner. Or damp dev unit. They are not rare this time of season.
          Sent from my iDon't believe in marketing device using Tapatalk
          Firmwares HERE
          • allan
            RTFM!!
            • 5462
            Hehe, remove debris from iu
            Whatever
            • fixthecopier
              ALIEN OVERLORD
              • 4713
              Is there a mouse in the copier, they usually attract snakes.
              • antone
                • Oct 2014
                • 344
                Laser unit bad!!
                • ianferron
                  I try replacing drum and transfer roller with problem coming back. I did replace the dev unit and put fresh dev mix and problem is finally gone. I am trying to post a sample. Still not sure what was the problem. On the snake pattern I can rub off what feel like dev mix.
                  • allan
                    RTFM!!
                    • 5462
                    Drum arcing. i know this well if there is a small hole in the DEV seal (normaly deep side) the drum would leak to the mag roller. change drum and dev tank or fix seals. Get DS collar kit.
                    Fong Kong toner?
                    Whatever
                    • Hansoon
                      • Sep 2007
                      • 3384
                      Well wit THAT information + your scan it would have been much easier to diagnose the problem..........
                      Hans
                      • nmfaxman
                        • 1702
                        Arc Marks. Dark bands are charge, light marks are transfer in most cases.
                        Copier repair 101.
                        • ianferron
                          I didn't had a sample with me and customer was closed for the holiday. I still have the dev unit and will inspect for hole in mylar covering the mag roller. Seem like a common problem with these models. Had another 363 with same problem 3 weeks ago, cleaned the charge corona unit but they never called back.
                          • ianferron
                            Customer called with same problem again. New drum, new dev unit. I am pulling my hair cause I have no idea what else could it be.
                            • fixthecopier
                              ALIEN OVERLORD
                              • 4713
                              I would put the new drum and dv unit in another machine. If it works in another machine, I would start going backwards into the machine and change the hv power unit.
