I have had a issue printing reds on this machine. Whenever I print red type, I get a ghosting affect around all of the type. It almost looks like the paper isn't absorbing all of the toner. I have tried multiple paper types and I get the same problem. Does anyone know a setting that might help eliminate this problem?
C500 ghosting reds
Lindsay Hundley
random
Lindsay Hundley
random
Well, what can I say. You need to get some some volume on the machine and this fault will disappear. This has been fixed on c6500 by spinning the dev tank in reverse, sorry no real fix for c500. There is a vs/vp dip switch but it doesn't really make a lot of difference.Comment
I wouldnt be too concerned!!!If you are getting reasonable RED reproduction AT ALL on a C500 you are doing wondersNo help i know but couldnt resist
...si
SPECIAL NOTE: Solution contribution by Mark D'Attilio, Production Print/SSD
Hope this helps.
RobThe family that prays together, stays together!
Smile God created you and He doesn't make mistakes!
Relax, God IS in control!
Be still and know that I am God
Ps 46:10Comment
