Bizhub C451 - many warning codes - copier not operational
  • thendral
    • Mar 2011
    • 82
    [Error Code] Bizhub C451 - many warning codes - copier not operational
    Hello All,
    One of my customer has Konica Minolta bizhub C451 - displaying bunch of warning messages:
    The following notification message is being displayed.
    <<Page 1>>
    Cannot Scan
    Tray 1 cannot be used currently.
    Tray 2 cannot be used currently.
    Tray 3 cannot be used currently.
    Tray 4 cannot be used currently.
    LCT cannot be used currently.
    Bypass Tray cannot be used currently.
    <<Page 2>>
    Hole Punch cannot be used currently.
    Staple cannot be used currently.
    Unable to Half-Fold/Center Staple-Fold/Tri-Fold
    Z-Fold cannot be used currently.
    Post Inserter cannot be used at this time.
    I checked all the connections to ADF, all the electrical connections to sorter and other trays.
    Being Ricoh tech, I not sure if any settings I am missing.
    Any help in this regard is highly appreciated.
    Thendral
  • thendral
    • Mar 2011
    • 82
    Re: Bizhub C451 - many warning codes - copier not operational
    Oh Sorry forgot mention, it is not recognizing the Fiery controller either. It is not showing up in the utilities screen.
    • allan
      RTFM!!
      • 5462
      go check trouble isolation maybe you can unlatch them. if not i think the OACB it wacky. Or a missing voltage from the supply.
      Whatever
      • KingofMorton
        • Apr 2015
        • 23
        Go to System 1, problem isolation, make sure they are all on set. Power cycle the machine and see what happens. You may have to "unset" them, power cycle, the "set" them again and power cycle.
        • thendral
          • Mar 2011
          • 82
          Thanks a lot KingofMorton. I did set and unset then the message disappeared.
          Thanks a lot.
          Not really sure what happened. But any way got it up and running.
          Regards
          Thendral
