Konica Minolta 215
Re: Konica Minolta 215
Wired connection> connected> ping results fine. Packets received and sent fine. Excellent ping results konica minolta 215.jpg
Turn of wifi adapter; install driver ic-209? PCL6 the only driver that doesn't return syntax errors! Great installed (shows as connected printer properties etc brilliant. Print test page please: No!
Delete printer/uninstall. Go to printers>add printer>finds and attempts to install printer(auto)> driver error..
Printers>add printer>finds printer (manually)>try to install drivers (manually).. driver error..
It's not a hardware issue; is it because I'm in Oman (Gulf/Middle.East)?! I don't why that would make any difference though!
What now folks? Kick it and walk away?Comment
Yep tried the GDI driver and PCL. All drivers I've tried give syntax or OS errors expect the controller IC-209 which installs and shows as working but without functionality.
Should I try the older drivers? I've only been trying the newer/latest releases as my assumption is these are most up to date and likely to work?!Comment
Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you!
THANK YOU! EVERYONE!
Seriously, Thank you everyone! You've taught me sooo much about printer networks, diagnostics, ip addresses, ethernet/crossovers..
Wow! What a lesson! Feel like dancing and kissing you all!!
You guys are fantastic!!! ThanksComment
Congratulations on your success! Everyone else calls me Cat. That will work fine. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
