Konica Minolta 215
  • Cloudlessdreams
    • May 2015
    • 17
    Re: Konica Minolta 215
    Originally posted by suomi
    NC-504 IS GDI
    IC-209 IS PCL
    Which network card are you using???
    Sorry I have no idea. It's a broadcom wireless card.. How do I check?
    • Cloudlessdreams
      • May 2015
      • 17
      Originally posted by allan
      Its under the port settings on the printer driver. Go to the port tab and select configure port, select LPR and change the queue name to "Print"
      I'll try this and come back to you. Thanks guys
      • allan
        RTFM!!
        • 5462
        If that does not work then look for the IC-209 specific driver.
        Download Centre - KONICA MINOLTA Europe
        under product type select controller then IC-209.
        Whatever
        • Hansoon
          • Sep 2007
          • 3380
          #19
          Huh? Whut?
          Hans
          • CompyTech
            Super Tech
            • Feb 2011
            • 706
            #20
            He means the network card inside the printer.. Not sure how to tell really. AFAIK they both look the same, might as well throw it in the trash and order the IC209.
            • Cloudlessdreams
              • May 2015
              • 17
              #21
              Ok so I've tried every driver suggested (PCL6/ic-209 and GDL), most of which give invalid arguments or windows error codes except the PCL6 driver which installs without any error codes. It shows in printers as working and the default printer. When test printing or any other printing nothing. I then switched on LPR and changed the que to Print. Still nothing..
              I've disabled the IPP settings in control panel. Pagescope itself is temperamental, right now its not working but I'm sure it'll work again soon but the printer pings and connects when it wants.
              Am I using the wrong port? (sounds silly I know..) Also, could I be using the wrong network cable? I don't know which network card the printer has but if tried all drivers. I've got a feeling this is something really stupid, something which I have no idea about.
              • allan
                RTFM!!
                • 5462
                #22
                get a Laptop and a cross over cable (most new laptops you can use a straight cable). Set the laptop to the same range as the printer and ping it from there use "ping x.x.x.x -t" to let it ping continuously, wiggle the the cable end that is plunged into the machine to check if there is any physical problem there.
                Then install the driver(s) to the laptop and see if it prints.
                Whatever
                  • 23002
                  #23
                  Thanks mate I'll give it a shot and let you know.
                  The help is really appreciated!
                  Maybe he'll like it better when you say it allan. =^..^=
                  • allan
                    RTFM!!
                    • 5462
                    #24
                    oops missed your post on the first page .
                    Whatever
                      • 23002
                      #25
                      No offense taken. It's a good idea. I really do hope he'll try it. =^..^=
                      • Cloudlessdreams
                        • May 2015
                        • 17
                        #26
                        Sorry I should've tried this. Just being lazy.
                        I'll let you know what happens..
                        • Cloudlessdreams
                          • May 2015
                          • 17
                          #27
                          Ok so I've connected the printer to my laptop and changed the TCP settings (I think that's changing the range?) to the same as the printer. I ping in cmd and its giving me replies regularly/consistently wriggling the wire, nothing changes. When I open up the Local Area Connection it states packets sent xxx received 0.
                          Troubleshoot gives me 'doesn't have a valid IP config (I thought this isn't how to change the 'range' I don't know how else?)
                          Sorry noob =(
                          Then trying to install drivers is futile!
                          Thanks again
                            • 23002
                            #28
                            #1) are you using a crossover cable?
                            #2) what IP is set on the printer?
                            #3) what IP is set on the laptop?
                            The IP's must be in the same range, but not the identical, for example:
                            192.168.1.200 and 192.168.1.201
                            I think that will help. =^..^=
                            • Cloudlessdreams
                              • May 2015
                              • 17
                              #29
                              No I don't think it's a crossover. It's cat.5 which I'm sure isn't but my laptop is pretty new so it shouldn't be a problem right?
                              Printer I have 192.168.0.112
                              Laptop I also set to 192.168.0.112 (like a proper noob lol) obviously network gave me errors.
                              I'll try to change it to 192.168.0.113/4 or 5???
                              Oh and everything else has to be the same right like subnet mask, gateway (obv) etc? Dns etc? *just don't want to put in something stupid like identical IPs
                              Thanks =)
                                • 23002
                                #30
                                Thanks =)
                                .113, .114, or .115 will be fine for an IP.
                                Subnet and Gateway remain the same. You can enter a DNS if you like, but it's unnecessary.
                                You're getting there. I made (and continue to make) all the same mistakes, so don't feel too bad. You're still trying things, which is important. And you have a sense of humor about it all. It's unhelpful to beat yourself up over things you don't know.
                                Personally I feel that the my greatest asset as a diagnostitian is blockheaded stubbornness. Unwillingness to give up. =^..^=
