yellow background print bizhub c364
  • toony
    • Jun 2025
    I use a bizhub c364.
    Yesterday it started printing all yellow background for any colored print i have. gues it might be some sort of yellow toner spill. but it does not do this when i do a print in greyscale. pls what can be done!
  • fixthecopier
    ALIEN OVERLORD
    • 4714
    Re: yellow background print bizhub c364
    Most likely, replace the yellow image unit.
    • allan
      RTFM!!
      • 5462
      Have you tried to use the corona cleaner?
      Whatever
      • KingofMorton
        • Apr 2015
        • 23
        Cut a long strip of paper and slide it under the yellow drum and block the laser glass. If the yellow goes away then the laser is the problem.
        • shamnad abdullah
          service engineer
          • May 2015
          • 24
          Remove the high voltage board and assemble it,make sure that all connections are touching properly
          best of luck
          • dhaneshkumar
            I have same issue konica c452 printer plese help me.
            • Synthohol
              Certified Konica Expert
              • Mar 2016
              • 5799
              upgrade to a newer machine.
              or maybe tell us what you have done so far? like any of the advice above?
